Author Topic: Display element type  (Read 5970 times)
Tehila1
« on: April 01, 2015, 11:55:03 pm »
Is it possible to display type for each diagram object?
I mean 'Package packName' for a  package or 'Class className' for a class, etc.
Thanks.
Re: Display element type
« Reply #1 on: April 02, 2015, 03:20:55 am »
Where?
Tehila1
« Reply #2 on: April 02, 2015, 08:13:36 pm »
Where?
On the diagram element itself- beside the name I would like to show ots type. Possible?
« Reply #3 on: April 02, 2015, 09:24:15 pm »
I would say: no. You can modify the display of elements with a shape script. But only for stereotyped elements. And you'd need an individual shape script for each possible stereotype.
Tehila1
« Reply #4 on: April 02, 2015, 10:03:52 pm »
Well, Using the shape script as you suggest, I did the following:
PrintWrapped("#Type#");
However, I get the textbox with typ at top-left of element.
Is it possible to set its position to the enter of element?
Thanks in advance!
« Last Edit: April 02, 2015, 10:04:29 pm by avoda234 »
« Reply #5 on: April 02, 2015, 11:08:59 pm »
Try replacing the whole script by this one:
decoration centerType {
  orientation = "CENTER";
(and have a look into my Shape Script book)
« Last Edit: April 02, 2015, 11:10:40 pm by qwerty »
Tehila1
« Reply #6 on: April 03, 2015, 12:35:59 am »
Thanks a lot!
One more question please:
Can I set an image at the background and the textbox over it?
I tried to merge the code above with the image() function with not much success. Is there any trick or simply impossible?
« Reply #7 on: April 03, 2015, 07:51:09 am »
When using this script:
shape main {
  Image("B", 10, 90, 90, 10);
I got the image in the background and the text (rather) in the center of the element.
Tehila1
« Reply #8 on: April 12, 2015, 06:14:43 pm »
shape main {
Thanks q.
This shape script indeed put the image at background with text centralized on it.
One more thing please:
I would like to give the option to override the default text.
Is it possible to make the textbox writable?
« Reply #9 on: April 13, 2015, 02:10:22 am »
No (AFAIK). You can write over attributes/operations. Maybe notes? What you can do is to use a tag and change that.
