Author Topic: Exclude packages from report by Custom SQL  (Read 4791 times)
survex
« on: April 09, 2015, 01:34:57 am »
Say I have model and I want to exclude all packages which name ends by "--" like following pattern "*--".
I've playing around with Generate Documentation > Options > Except where Query excludes Custom SQL, but can't figure out how it works.
Does anybody has working examples of such query?
Michel Gibelli
Re: Exclude packages from report by Custom SQL
« Reply #1 on: April 11, 2015, 02:22:19 am »
I asked the same question in :
http://www.sparxsystems.com/cgi-bin/yabb/YaBB.cgi?num=1412081849/
and Adam gave me an answer
In my case, I use the following request :
SELECT t_package.Package_ID AS ExcludePackage
FROM t_package, t_object
WHERE t_package.Package_ID = #PACKAGEID#
AND t_object.PDATA1 LIKE t_package.PACKAGE_ID
AND (t_object.stereotype is null or t_object.stereotype <> 'Domaine fonctionnel')
I hope it will help you
Michel
« Last Edit: April 11, 2015, 02:25:29 am by mgfr13 »
survex
« Reply #2 on: April 13, 2015, 05:05:11 am »
Thank you very much!!!
But is there any way to exclude all not only one package found, but all subpackages?
« Reply #3 on: April 13, 2015, 09:23:15 am »
Recursion in SQL is almost impossible. You could probably hard code a certain depth level. Or you need to use automation.
