Author Topic: Set Element Properties by Diagram Type  (Read 5288 times)
Tehila1
« on: April 21, 2015, 09:47:15 pm »
Can element color be changed depending on the diagram type?
I tried the "Template Package"-  I set red class on a Class diagram and a yellow one on a Component diagram.
In any case when I drag a class - even on a Component diagram, its color is red (and not yellow).
What is wrong?
Modesto Vega
Re: Set Element Properties by Diagram Type
« Reply #1 on: April 22, 2015, 02:53:11 am »
You can set the color locally for each diagram using the toolbox at the top of the diagram or globally using F4. The formatting toolbox at the top of the diagram overrides the global settings. Which method are you using to change the color of the class?
« Reply #2 on: April 22, 2015, 04:10:51 am »
Maybe you got mixed up with your various test. Try with a new blank repository.
« Reply #3 on: April 22, 2015, 09:25:03 am »
What is wrong?
Template Package doesn't distinguish between a class on a Class diagram and a class on a Component diagram. EA just copies the first class it finds.
« Last Edit: April 22, 2015, 09:25:22 am by KP »
Tehila1
« Reply #4 on: April 22, 2015, 10:10:56 pm »
What is wrong?
Well, so what is the best way to set different color to non- UML elements (such as Archimate elements), depending on diagram type?
Non UML elements cannot have more than one stereotypes.
Ideas?
« Reply #5 on: April 22, 2015, 10:23:28 pm »
Yes, write an add-in...
