Author Topic: change system templates (fragments) ?  (Read 4334 times)
JohnDoe
  • EA rocks !
« on: April 28, 2015, 08:38:32 pm »
How can I change the given system templates (e.g. fragments), which are used by EA to generate the documentation ?
Modesto Vega
Re: change system templates (fragments) ?
« Reply #1 on: April 28, 2015, 10:08:43 pm »
Which version of EA are you running? On EA12 you can create your own documentation fragments based on existing system templates. Just make sure you select the right system template on the "Copy from" list.
JohnDoe
  • EA rocks !
« Reply #2 on: April 28, 2015, 11:54:59 pm »
EA 12.
The problem is, that if I copy&paste a fragmet, that the TemplateSelector will pick the standard "System-Use Case" and not my "Model->myUseCase".
How do I tell the EA TemplateSelector to use my fragment template when it finds a Use Case in my package ?
Modesto Vega
« Reply #3 on: April 29, 2015, 12:14:14 am »
Instead of creating a Fragment, have you tried creating a Template. If you have a user define template (instead of a fragment), you can generate documentation from it.
Fragments are to be used only Templates.
« Reply #4 on: April 29, 2015, 09:03:05 am »
From memory, if you create a fragment with the same name as a system fragment it will override the system one when generating.
