Author Topic: Use case doc format change - RTF generator?  (Read 3540 times)
stevo
« on: September 16, 2009, 08:22:14 pm »
Hi
Have done a great deal of use case testing and was hoping to be able to change the col format of the current use case document generated by EA.
Would it be possible to create individual tables one for the Basic Flow and one for each Alternate flow with each table containing the cols Step, Description, Alt flow ref, Business rules?
With this structure I find it easier to trace the important flows through a use case diagram generating all possible test cases based on business rules.
Steve
Dermot
Re: Use case doc format change - RTF generator?
« Reply #1 on: September 17, 2009, 05:02:41 pm »
Basic Flow and Alternate flow are both: Secnario.type, so they are listed from the same field Element:: Scenario.Type. Hence the can only be listed in one table.
« Last Edit: September 17, 2009, 05:07:27 pm by Dermot »
