Author Topic: Baseline information in generated documentation ?  (Read 8016 times)
JohnDoe
  • EA rocks !
« on: April 28, 2015, 06:50:47 pm »
I have altered the content of a package during several versions, that I stored as baselines. Now I would like to add this information about the baseline changes (when and who) to the generated documentation report.
Is it possible to add information about the baselines of a package into the documentation when generating the report ?
JohnDoe
  • EA rocks !
Re: Baseline information in generated documentatio
« Reply #1 on: May 04, 2015, 06:11:48 pm »
any idea ?
Stefan Bolleininger
« Reply #2 on: May 04, 2015, 07:13:52 pm »
Yes,
this is possible, if you use template fragements and SQL-Querys for the baseline. "Select * from t_document Where Type = Baseline AND... "
A Video turorial from Scott Hebbard using this feature is available on Youtube.
Best reagrds
Stefan
JohnDoe
  • EA rocks !
« Reply #3 on: May 04, 2015, 08:23:36 pm »
Thanks, Stefan !
Dermot
« Reply #4 on: May 05, 2015, 12:10:05 pm »
If you do want to create an document with differences between the Baseline and the current model you can try the following:
- Export the XMI from the Baseline and import it into another model
- Create a report template and copy this to the external model
- Run reports from both models
- Use Word or Libre office to do a document compare between reports to produce a single report with the changes visible.
JohnDoe
  • EA rocks !
« Reply #5 on: May 05, 2015, 05:17:25 pm »
Sounds a bit complicated.
What I simply need is a history of changes like:
Version 0.1 - 01.01.2015   - UserA   - Changed content ABC
Version 0.2 - 04.01.2015 - UserB  - added diagram C & D
Version 0.3 - 10.01.2015 - User A - accepted changes
It is the information of the baseline history, not the difference between the models.
« Reply #6 on: May 05, 2015, 06:58:46 pm »
Check t_document WHERE ElementType="Baseline" (see p. 26 of my Inside book)
« Last Edit: May 05, 2015, 06:59:30 pm by qwerty »
