Author Topic: Difference- Lifeline or Instance  (Read 3639 times)
Tehila1
« on: May 11, 2015, 10:48:34 pm »
Is there difference between adding an instance or a lifeline to sequence diagrams?
Thanks in advance!
Re: Difference- Lifeline or Instance
« Reply #1 on: May 11, 2015, 11:06:22 pm »
Not really (though EA makes a difference in the appearance in the browser). Both represent instances.  You should choose either to make your models consistent. In the past I just used instances but nowadays I tend to use lifelines instead. Probably because the menu (and the overall situation) was more messy in the past (so the cleaned that at least).
« Last Edit: May 11, 2015, 11:06:51 pm by qwerty »
