Author Topic: Relationship Matrix and applying of Model Search  (Read 5037 times)
Slávek Rydval
    • homepage
« on: May 11, 2015, 12:45:15 am »
Dear folks,
I have a custom search which returns two rows as a result. When I want to use it in relationship matrix, it doesn't work even one of the columns is CLASSGUID as is stated in documentation:
select ea_guid as CLASSGUID, Object_Type AS CLASSTYPE, *
      from t_object
            where object_id in (2130, 2205)
What else must be fulfilled to obtain the result set in RM?
Thanks in advance.
EA 12 (build 1213), EAP repository, no addins.
Re: Relationship Matrix and applying of Model Sear
« Reply #1 on: May 11, 2015, 12:22:45 pm »
try this
select ea_guid AS CLASSGUID, Object_Type AS CLASSTYPE, *
     from t_object
Yes, some areas in EA are very (case) sensitive.
« Reply #2 on: May 11, 2015, 03:22:51 pm »
I remember this being reported here a while ago (the first AS needs to be capitalized). So it's still not fixed.
Slávek Rydval
    • homepage
« Reply #3 on: May 12, 2015, 05:53:56 pm »
Thanks, Geert. It works. It is pretty surprising to me that even a keyword has to be capitalized.
