Author Topic: Constraint Block script in SysML  (Read 6953 times)
blabla
« on: May 07, 2015, 11:36:02 pm »
I would like to read data from a excel file
in a constraint block script
how could I do this? or is this not possible
Re: Constraint Block script in SysML
« Reply #1 on: May 08, 2015, 12:27:16 am »
Ehrm, what is a constraint block script?
« Reply #2 on: May 08, 2015, 08:34:35 am »
qwerty - A constraint block is a unit of behavior in a parametric diagram. In EA, that is defined using a one of the scripting languages EA supports. (I can't remember which. It's been a long time)
blabla - You should be able to create an activex object to read from excel. The complicating factor is that your script is used inside a larger script and I'm not sure how that will interact.
« Last Edit: May 08, 2015, 08:35:27 am by simonm »
« Reply #3 on: May 08, 2015, 06:20:21 pm »
Oops. I missed the SysML in the title  :-[ Thanks for clarification.
« Last Edit: May 08, 2015, 06:20:37 pm by qwerty »
blabla
« Reply #4 on: May 15, 2015, 04:06:56 pm »
My idea is to add a vba script to a constraint block. With the vba script I can read the excel sheet
blabla
« Reply #5 on: May 15, 2015, 06:43:31 pm »
Does anyone know why this code doesn't work? Script language = java
int a=400;
output=a
if I write this code it works
output=400
« Reply #6 on: May 20, 2015, 09:08:59 am »
You're using javascript not java. It's not a strictly typed language and doesn't know what to do with the "int".
