Author Topic: How to add Tagged Values as default?  (Read 4849 times)
stedou
« on: May 20, 2015, 05:29:28 pm »
hi,
I have created a stereotype and I want to associate some Tagged Values with it so that when I create (or apply) the stereotype the tags are added with a default value. Can any one help?
Stephen
Re: How to add Tagged Values as default?
« Reply #1 on: May 20, 2015, 05:31:07 pm »
Stephen,
The proper way is to create a UML profile that links the tagged values with the stereotypes.
The "quick and dirty" way is to use the template package.
You should find more info on both options in the help file.
stedou
« Reply #2 on: May 20, 2015, 11:41:06 pm »
hi,
This doesn't appear to be easy. I had a look at creating a "Profile" but can't see how it is done from the docs. Could find out how to create a Template Package either.
Stephen
« Reply #3 on: May 20, 2015, 11:53:49 pm »
Use the Index instead of Search in the help to search for "template".
You also might be interested in this article: http://community.sparxsystems.com/tutorials/552-24intro-to-creating-a-mdg-file
« Last Edit: May 20, 2015, 11:55:11 pm by qwerty »
stedou
« Reply #4 on: May 21, 2015, 12:02:57 am »
hi,
Ok, thanks. I'll take a loko at that.
Stephen
