Author Topic: Creating RTF Report based on SQL Query  (Read 4058 times)
tobinho
« on: May 25, 2009, 06:13:01 pm »
I would like to create a rtf report based on a SQL Query. I read the manual for that but i have a problem i can`t solve.
Here my Query:
SELECT Requirement.ea_guid AS CLASSGUID, Requirement.Object_Type AS CLASSTYPE, Requirement.Name AS ReqirementName, UseCase.Name AS UseCase
FROM
t_object AS UseCase
INNER JOIN
(t_connector AS Connector INNER JOIN t_object AS Requirement ON Connector.End_Object_ID = Requirement.Object_ID)
ON UseCase.Object_ID = Connector.Start_Object_ID
WHERE Requirement.Object_Type='Requirement'
AND UseCase.Object_Type='UseCase'
Here my Description:
I can create a rtf report for the requirements i get from the result - but i also would like to get the second element "t_object UseCase" to get an connection between requirement and usecases.
The search create an overview of all requirments in project and link them to a use case.
Here my Question(s):
How can i get the result of the field "UseCase" in the rtf report ?
I also find a option in "Tools/Option/General" named "Allow custom RTF tags in reports" ? --> Have this one to do with my problem?
Thanks for your help !  ;)
Tobias
« Last Edit: May 25, 2009, 06:14:08 pm by tobinho »
Rodrigo Nunes
Re: Creating RTF Report based on SQL Query
« Reply #1 on: May 21, 2015, 06:39:55 am »
Just does not work very well when you use t_object.Package_ID in (# Branch #), it displays an error and close.
« Reply #2 on: May 21, 2015, 01:46:34 pm »
Rodrigo,
You problem does not appear to be related to the issue of the OP (from 2009)
You better create a new topic and explain your context a bit.
