Author Topic: Version 12 backward compatibility to Version 10?  (Read 3377 times)
mtechera
« on: May 21, 2015, 06:28:01 pm »
a client of mine is using EA version 10. The client is also using a central repository to store the models in SQL Server.
I have EA 12 installed on my PC. Will this be causing any problems of I work on their models?
Can I connect to the repository and make changes to the model with my Version 12 or do I need to install the older version?
Mario
Re: Version 12 backward compatibility to Version 1
« Reply #1 on: May 21, 2015, 06:30:37 pm »
For most of it you won't cause any problems.
Things to avoid:
- enumerations (v10 uses classes with enumeration stereotype)
- embedded office documents
It's not that these will crash the v10 application, but from v10 they will not be able to use those.
mtechera
« Reply #2 on: May 21, 2015, 07:15:45 pm »
Thanks Geert!
