Author Topic: EA COM Object  (Read 5128 times)
Tehila1
EA COM Object
« on: June 02, 2015, 04:38:25 pm »
I would like to change EA COM object to DCOM, in order to enable Windows Service to access EA repository.
I cannot find Enterprise Architect application in list of COM components, nor EA neither sparks or something similar.
(access the list by : Run-> type dcomcnfg -> Component services->Computers->My Computer->DCom Config> application name???)
What is the application name in the COM objects list?
Thanks in advance!
Re: EA COM Object
« Reply #1 on: June 02, 2015, 07:38:25 pm »
You can not run EA as service. You need a logged on user.
Re: EA COM Object
« Reply #2 on: June 02, 2015, 08:29:20 pm »
I don't get it.
It looks like you've asked the same question (each time worded a bit different) at least 4 times here and on Stackoverflow.
Do you really think that is going to do any good? :-?
Tehila1
Re: EA COM Object
« Reply #3 on: June 02, 2015, 09:00:59 pm »
I don't get it.
Each time I encounter another barrier. you can see the details added one by one...
Am I the first in world to run EA via service?
Re: EA COM Object
« Reply #4 on: June 02, 2015, 10:33:03 pm »
At least someone that needs to be told more than once that it does not work. Check the LieberLieber source Geert mentioned.
