Author Topic: Class diagram class attribute: list  (Read 4944 times)
ecsgz
« on: June 09, 2015, 05:59:07 pm »
how can I add a list of enums or other class references as an attribute of a class? Example:
ClassA
- listofElements: List<ClassB>
Thank you for the help!
Re: Class diagram class attribute: list
« Reply #1 on: June 09, 2015, 06:45:57 pm »
Not sure which language that is, but generally you set the multiplicity for attributes to anything other than [1].
ecsgz
« Reply #2 on: June 09, 2015, 07:01:50 pm »
Thanks! How can I model it programming language independent? How to use multiplicity and collection attribute properties correctly, if I want to transform out of the class diagram later code, e.g. to Java or even to a XSD.
Moreover: How to define an attribute to be a map, e.g.
- itemMap: Map<ClassB, ClassC>
« Last Edit: June 09, 2015, 07:09:11 pm by ecsgz »
« Reply #3 on: June 09, 2015, 07:30:23 pm »
Key-Value-Coding can be modeled with an association class.
Syntactical representation of UML elements in a specific language is means of code generators. EA has a build-in generator with a proprietary scripting language (though i prefer to achieve even more using the API and simple file I/O).
