Author Topic: Filepath Length Limit  (Read 4580 times)
mike08
« on: May 29, 2015, 05:59:44 pm »
I'm adding file links to SysML blocks to refer to external information. During a change of the underlying file structure I started to hit the length limit of the EA Filepath field (Error DAO.Field[3163]). The link I'm trying to add to Filepath in this situation has 291 characters.
Is there a way to extend this limit? Without that I would loose the benefit of an easy access to external documents.
Best,
M.
Re: Filepath Length Limit
« Reply #1 on: May 30, 2015, 09:23:19 pm »
You could change the underlying table but that's not recommended. It might result in overflows in certain code parts of EA. You might send a feature request and take a looong breath.
mike08
« Reply #2 on: June 03, 2015, 12:04:40 am »
Thanks, will do (the feature request thing ...).
Best,
M.
« Reply #3 on: June 10, 2015, 12:13:59 pm »
You'll need more than a deep breath. In fact I doubt that even if all your friends, not so friends, and a number of EA trainers  wanted this ... but I waste my breath ...
See
Bug: File Path too short
« Last Edit: June 12, 2015, 06:23:29 am by skiwi »
SCare
« Reply #4 on: June 10, 2015, 08:53:50 pm »
This is very good! :)
