Author Topic: Issue with SQL  (Read 6125 times)
Guy Manning
  • UML Newbie :0)
Issue with SQL
« on: June 15, 2015, 05:30:20 pm »
Hi, newbie here
Got v12...1214 installed and I am trying to access an older repository on our SQL Server...standalone new eaps work fine
I can get into the SQL Model repository OK and look around but all the elements etc seemed locked...i.e. have puce boxes around them and the options to Save, Update disabled
Been told that I AM in the Users list for the SQL ...are there some things I need to check to work out why this is happening?
or is there something that has to be done to get V12 working with older SQL instances?
Guy
« Last Edit: June 15, 2015, 05:30:49 pm by GuyM »
Re: Issue with SQL
« Reply #1 on: June 15, 2015, 05:50:03 pm »
Is it possible that the security is turned on on that repository?
Try "Apply user lock" on an element on a diagram and then open its properties dialog.
Guy Manning
  • UML Newbie :0)
Re: Issue with SQL
« Reply #2 on: June 15, 2015, 05:57:04 pm »
Hi Geert
Yes if I 'Apply...' as you suggested, I can then indeed edit the element
Now...how do I do that for the whole repository (at once)?
Ta
Guy
Re: Issue with SQL
« Reply #3 on: June 15, 2015, 05:59:14 pm »
You can do the same on package level (check Package Control context menu)
Or you can simply turn off security if you don't need it anymore. (Project|Security)
Guy Manning
  • UML Newbie :0)
Re: Issue with SQL
« Reply #4 on: June 15, 2015, 06:00:03 pm »
OK think I already got the answer...Project > Security > uncheck Require User Lock...
Ta
Guy
Guy Manning
  • UML Newbie :0)
Re: Issue with SQL
« Reply #5 on: June 15, 2015, 07:20:57 pm »
As an add on to this....If I want to 'Diable Security' from a Project...when I try, it asks me for an Authorisation Key...as this repository is some years old...I do not have this key...what do I do?
Ta
Guy Manning
  • UML Newbie :0)
Re: Issue with SQL
« Reply #7 on: June 16, 2015, 12:18:19 am »
Thanks Qwery
As a Reg owner, I think I can look up the Auth key...checked on the EA help
Ta
G
