Author Topic: SysML, Parametric view  (Read 2498 times)
Stef
« on: June 10, 2015, 04:19:51 pm »
Hello together,
I try to work with the parametric views from SysML and use the EA (System Engineering Edition) 10.0.1010 (Build1010). My problem is that I can't verify the way of adding a script to an constraintBlock as descriped in the help or the book "Embedded Sstems Development using SysML" - .
>> Add Scripts to Constraint Blocks
>> Once your constraint blocks have been created, it’s time to add
>> Scripts. This is where you express the relationship / behavior of the
>> constraint block as an executable script. In Enterprise Architect,
>> right-click on each of the Constraint Blocks and select the
>> SysML | Add Element Script context menu option to add a script to
>> the constraint block.
I'm unable to find the "SysML | Add Element Script" button inside the context menu. Is there anything I have to set first so this feature becomes visible ?
Thanks and regards
Stef
Stef
Re: SysML, Parametric view
« Reply #1 on: June 16, 2015, 12:30:48 am »
The problem was, that the needed menu's are disabled for viewing. It is necesarry to enable thise thru the following menu:
Open: View | Workspaces and Commands > Commands.  To show all available menu options, select the "Complete" command set.
