Author Topic: Newbie - Selecting Elements and moving them  (Read 5486 times)
Guy Manning
  • UML Newbie :0)
« on: June 18, 2015, 08:44:44 pm »
Hi this may be a bit of a silly one ...but I am having trouble moving elements
I have an activity diagram, with swimlanes, but all the elements within the lane are too low and I want to drag them up a bit (within lane)
As there are quite a few, I thought I would CntrlA and then drag, but this then includes the swimlanes
If I want to just select the all the actual elements (non-lane) and drag is there a quick way to select and move these without having to Shift / Click on each one?
 ;D
Re: Newbie - Selecting Elements and moving them
« Reply #1 on: June 18, 2015, 09:14:45 pm »
You should be able to make the swimlanes (ActivityPartitions?) non selectable.
Right click on the element and uncheck "Selectable"
Then it will not be selected anymore and you can move the rest.
You can also try ALT-DRAG on a diagram. That does cool things as well.
Guy Manning
  • UML Newbie :0)
« Reply #2 on: June 18, 2015, 09:43:46 pm »
Thanks!
AndyJ
  • It's only a model
« Reply #3 on: June 19, 2015, 11:58:36 am »
Or select-all (Ctrl-A) then de-select the lane, by holding down the control key and clicking into empty space within the lane.
Andy
« Reply #4 on: June 19, 2015, 04:10:27 pm »
Ctrl-Click to deselect doesn't alsways work.
I'm still not sure when it works and when it doesn't. :-/
AndyJ
  • It's only a model
« Reply #5 on: June 22, 2015, 12:10:35 pm »
I think that this may occur when something transparent is in the foreground...
Right-click on the offending element and choosing "Z Order" then "send to bottom" seems to take away that kind of behaviour for me.
Andy
