Author Topic: Sequence diagrams, systemsuse actors or components  (Read 4099 times)
newarchitect
« on: June 22, 2015, 09:02:42 pm »
Hi all,
Looking for some advice please. I've modelled some of our systems using UML components. I also have some actors (e.g. customer etc.) which I use on some of the component diagrams. These actors may be reused for modelling use cases in the future.
I want to create some sequence diagrams. I can use the existing actors but just wanted to know what I should be doing for systems. Should I use the existing systems (which are components) or create actors for the systems as well?
Re: Sequence diagrams, systemsuse actors or compon
« Reply #1 on: June 22, 2015, 09:37:44 pm »
Create lifelines and link them to the existing components (use Ctrl-L to select the classifier).
newarchitect
« Reply #2 on: June 22, 2015, 10:12:26 pm »
Cheers qwerty
newarchitect
« Reply #3 on: June 22, 2015, 10:59:35 pm »
Sorry, silly question. What is the difference of dropping the component into the diagram as a lifeline as opposed to creating new lifelines and linking them to the components?
« Reply #4 on: June 23, 2015, 12:27:11 am »
Dropping an element onto a diagram will usually create a link and not an instance (except you changed the setting or apply that explicitly on drop). Whilst creating a lifeline creates a new instance which is then linked afterwards (so it's more safe doing it this way).
Now the un-asked question: why do I need instances? Well, it's hidden somewhere in the documentation. If you use XMI ex-/import links will clobber your sequence diagram and instances won't. Unfortunately EA does not hinder you to use non-instances in SDs  :(
