Author Topic: Documentation with multiple level Child elements  (Read 3883 times)
Michael Boyer
« on: June 26, 2015, 02:03:39 am »
I am using EA 12 and trying to use the templates to display elements that are multiple levels deep.  I have some child elements that are 4 levels below the package and can't seem to find a way to have them picked up in the documentation.  Any suggestions?  I see the package, element and child element but I need to go two levels below that.
Re: Documentation with multiple level Child elemen
« Reply #1 on: June 26, 2015, 02:51:26 am »
You can if you use Virtual documents and model documents.
What you basically do is create a model document and in it's tagged values define a template, a search, and a search value. Make sure that the search returns exactly the elements you need.
As an alternative you could also create a script or SQL fragment and get the values you need through the SQL or script.
For both ways of working there are excellent learning center topics (Alt-F1)
« Last Edit: June 26, 2015, 02:51:43 am by Geert.Bellekens »
Michael Boyer
« Reply #2 on: June 26, 2015, 03:07:25 am »
Thanks for the reply I am using Virtual Documents and have a template defined, I haven't seen the search and search values, I will review the help for that
