Author Topic: RTF document generation TEXT vs IMAGE  (Read 2745 times)
Patrik Mihal
« on: July 01, 2015, 09:49:30 pm »
I would like ask you, how would be possible to simple show a diagram text element in the generated RTF document as a TEXT (not as an image).
I use EA version 12.
Thank you in advance
Patrik
Re: RTF document generation TEXT vs IMAGE
« Reply #1 on: July 02, 2015, 04:07:51 pm »
Hi Patrick,
A text element is an also an element just like a class or use case.
It resides in the same folder as the diagram, only not visible in the project browser.
I think you should be able to report this element if you start from the package.
If that doesn't work out for some reason then you can always use an SQL fragment to get the requirement information.
Patrik Mihal
« Reply #2 on: July 02, 2015, 05:37:22 pm »
Hi Geert,
Thank you very much for advice. I will try to use SQL fragments, but i have to learn how to do :-)
Have a nice day.
Patrik
PS: i see the text elements in my RTF, but i would like to have it as editable text, not as image.. :-(
