Author Topic: Element resize & Port array  (Read 4602 times)
strongpine
« on: July 06, 2015, 11:45:34 am »
i'm using EA 9.
"Add New" Function gets the locate information by string. but I want to insert the information as a formula. something like, "2 x+10". is this possible??
if you feel hard to understanding, I apologize about my bad english skills.  :-[ :-[
Re: Element resize & Port array
« Reply #1 on: July 06, 2015, 02:48:38 pm »
Can you explain what you mean by "locate information"?
Takeshi K
    • Sparx Systems Japan
« Reply #2 on: July 06, 2015, 04:40:08 pm »
Hello strongpine,
You can create a new Diagramobject by AddNew function with empty location information, then you can specify Diagramobject.Top, Bottom, Left and Right properties by using the 'formula'.
After setting the properties, call Diagramobject.Update.
t-kouno
strongpine
« Reply #3 on: July 07, 2015, 10:16:55 am »
Hello, qwerty! i mean "l = 10; r=20; t=10; b=20" like this!
and i think "T kouno" solve the problem!
I appreciate all you guys answer! Thx!
strongpine
« Reply #4 on: July 07, 2015, 02:55:18 pm »
[code][dim testDiagramObject as EA.DiagramObject
      set testDiagramObject = diagramObjects.AddNew( "", "" )
      testDiagramObject.top      = 150
      testDiagramObject.bottom= 200
      testDiagramObject.left = 100
      testDiagramObject.right = 200
      testDiagramObject.ElementID( testElement.ElementID )
      testDiagramObject.Update()/code]
it isn't work... :'( :'( what's wrong?
« Reply #5 on: July 07, 2015, 07:32:05 pm »
Down is negative. Like in real cartesian systems if top left is (0|0) you need to address the y-coordinate negative to see it.
