Author Topic: Patterns ain't patterns  (Read 4194 times)
« on: July 07, 2015, 11:38:16 am »
With apologies to the the famous Castrol "Oils ain't oils" advert (Google/Bing it).
Am I correct in understanding that there are TWO types of patterns in EA?
  • UML Patterns - used for generating clusters of inter-related items
  • Model Patterns - used for generating package structures.
You typically use a Model pattern when you are creating a new package.
Both can exist in an MDG Technology.
TIA,
« Last Edit: July 07, 2015, 11:40:35 am by PaoloFCantoni »
Re: Patterns ain't patterns
« Reply #1 on: July 07, 2015, 02:31:24 pm »
Feels about right to me.
Sunshine
  • Its the results that count
« Reply #2 on: July 08, 2015, 06:48:45 am »
There is a new feature called re-usable asset library. Haven't had a chance to look into it but I get the impression you can use that to manage patterns too.
Happy to help
« Reply #3 on: July 08, 2015, 09:53:32 am »
Yes, normally an RAL is essentially that.  However, we'll need to see how Sparx has implemented it exactly to confirm/deny.
As I understand it, Sparx's RAL relies on Cloud Services (which is one reason I'm investigating them at present) - or have I got that wrong?
« Reply #4 on: July 08, 2015, 02:10:33 pm »
No, I think you got that wrong.
AFAIK RAL just uses a another database on the same server.
Like doing queries over two databases that are hosted on the same database server.
But I've never tried it out for real yet.
smendonc
  • I love YaBB 1 Gold!
« Reply #5 on: July 08, 2015, 03:23:09 pm »
You do require cloud services to be running to use the RAL feature.  The only access provided is through a http/https url not a regular database connection. The RAL is just another database, but it doesn't have to be on the same server or even a server at all.
I tested the setup with both a SQL server database acting as the RAL on the same server and using a firebird database accessible through a cloud service url (though I'd never implement that in a production environment).
« Reply #6 on: July 08, 2015, 03:44:53 pm »
Yes indeed. I just looked at the actual manual (that helps sometimes  ;)) and I was completely wrong.
I don't know where I got that idea  :-[
