Author Topic: Showing user stories in relationship matrix  (Read 4400 times)
mrblack12
« on: July 10, 2015, 02:05:45 am »
I can't seem to get a relationship matrix to show user stories, neither as source nor as target. The matrix does show artifacts, documents and checklists (all as stereotyped artifacts from the Document toolbox), but none of the other stereotypes. I have linked business rules (stereotyped requirements) to user stories using a trace link but only the business rules show up in the matrix...
Any ideas?
Re: Showing user stories in relationship matrix
« Reply #1 on: July 10, 2015, 01:59:25 pm »
If it doesn't work with the stereotype you can maybe use a model search as source or target.
In the search you should be able to limit the results to a specific stereotype.
mrblack12
« Reply #2 on: July 11, 2015, 06:26:15 am »
Geert, unfortunately that didn't work but I figured it out: you need to select <All> as Type instead of UserStory. And as long as you only have user stories defined in the selected package it works fine.
But the fact that selecting UserStory as Type doesn't yield any result, and <All> does, sounds like a bug to me. What do you think?
Rick
