Author Topic: Diagram Background Colour - HTML  (Read 4382 times)
jdavies86
« on: July 17, 2015, 02:22:13 am »
I have changed the CSS to be in-line with the company colors I work for. I have changed the diagram color to also reflect the companies theme. But, the HTML diagrams still have a white background.
Anyone know how/if I can generate the images with the background color taken from the diagram?
Cheers,
Jez
« Last Edit: July 17, 2015, 02:23:06 am by jdavies86 »
Sunshine
  • Its the results that count
Re: Diagram Background Colour - HTML
« Reply #1 on: July 17, 2015, 06:43:59 am »
As far as I can tell the diagrams generated in HTML and RTF always have a white backgrounds and there is no way to change it. A Good idea for a future feature though.
If you really can't live without a coloured background then a possible work around is to put a boundary object on the diagram. Set the boundary to solid fill by double clicking on border and selecting border style solid. Send the boundary to the bottom z order so its behind all the other objects on the diagram by right clicking menu >z-order> send to bottom. Stretch to the size of boundary to size of the diagram. And finally change the line and fill colours to those that you desire.
Hope that helps.
« Last Edit: July 17, 2015, 06:45:25 am by phenzell »
Happy to help
Monsieur
« Reply #2 on: July 24, 2015, 07:17:44 pm »
HTML generator is older than my grandma.
The diagrams are jpg/png so you always will have a white background (else use Sunshine solution bypass)
I wish they do-over the generator in order to get something that you can customise easily and or generate using scripting
