Author Topic: Search for changed elements  (Read 4467 times)
Grabt
« on: September 01, 2015, 07:28:40 pm »
Hi
I was wondering if EA provides the functionality to search for changes made by a specific user.
Scenario:
As a BA, i will make many changes to different elements [BPM, Use Case, etc]. Once my changes are done, I have to do a handover to the architect. The problem i have is to convey ALL the changes i made. Currently i have a excel spreadsheet which i update that identifies the changes i make. But the problem is that if i forget to update the spreadsheet, then i will not convey the full extent of the change to the architect. Hence i was wondering if i could filter/search for only changes made by me, or if i could tag all my changes and search for the tag.
Re: Search for changed elements
« Reply #1 on: September 01, 2015, 08:14:39 pm »
Have a look into the Auditing feature. That will log who did what and you can evaluate this log according to your requirements.
« Last Edit: September 01, 2015, 08:14:59 pm by qwerty »
Grabt
« Reply #2 on: September 01, 2015, 11:35:07 pm »
Thanks for the reply.
The Auditing feature is not enabled in my environment.
« Reply #3 on: September 02, 2015, 12:16:33 am »
Without you will not be able. You can alternatively write some triggers natively in the database (if it's not EAP files).
« Reply #4 on: September 02, 2015, 08:12:36 am »
The sticking point here is your requirement for changes by a specific user. As qwerty says, that's the only way EA tracks changes by user. The other alternative is using package baselines, which then offer a compare function. If there are multiple people changing one package you won't be able to see what each has changed though.
