Author Topic: Code engineering and C# enum classes  (Read 4706 times)
Guillaume
    • www.umlchannel.com
« on: September 09, 2015, 04:23:26 pm »
I generated the code for enumeration classes in C# from EA and I get the following:
public enum myEnum : int {
LITERAL1,
LITERAL2
I don't need this "int" type and unfortunately I cannot figure out from the Code templates nor from the C# class in EA how to remove it.
Any idea?
Guillaume
Re: Code engineering and C# enum classes
« Reply #1 on: September 09, 2015, 05:04:02 pm »
Have you removed the type from the literal values (attributes)?
Since v12 EA sets it to int, which is kind of a bug in my opinion. Literal values shouldn't have a type.
Guillaume
« Reply #2 on: September 09, 2015, 05:27:13 pm »
Hi Geert,
The attributes have been created without any type. They only have a name and the enum stereotype.
So it could be an EA 12 bug by the sound of it.
Guillaume
Guillaume
philchudley
« Reply #3 on: September 09, 2015, 06:11:40 pm »
Hi
The problem is with the enumeration override for the macro ClassDeclaration, specifically the last line of code:
%classTag:"enumType" ? ": " value : ": int"%
It appears this always evaluates to false
Either remove this line or simply comment it out as follows
$COMMENT=%classTag:"enumType" ? ": " value : ": int"%
Now should be all OK
Cheers
Models are great!
Guillaume
« Reply #4 on: September 09, 2015, 07:23:51 pm »
It worked !  :)
Due to my screen's resolution, I couldn't see and forgot about the stereotype overrides list underneath the Class Declaration template where enumeration is available.
Thanks Phil.
Guillaume
