Author Topic: SVN Problems  (Read 3844 times)
Dan Rasmussen
SVN Problems
« on: September 04, 2015, 10:59:20 pm »
Note: I am on EA 12.0.1214
I am trying to set up our model for CM by svn but am running into a number of issues that are confusing to me:
1. When I "add branch to version control", I get an error message stating:"An error occurred while checking the package into Version Control.  The Version Control provider reports the following error: svn:E000002: Can' open file "'c:\Users\DRASMU~1\AppData\Local\EA_C_msg.txt': No such file or directory.  I do see lots of files and directories being created in the svn folder that I point the project to.
2. If I check out a branch, the project browser twitches but I'm not sure if anything is really happening.
3.  If I change the model, the attempt to check in a branch, it says that there is nothing checked out.
So, I'm not sure if this is really working for me.  Maybe it is and I don't understand something but I was hoping that EA would prompt me to check out a branch if I try to mutate the model AND the I would see something in the project browser that indicates that the model is under CM control.
Any help or suggestions would be greatly appreciated.
Dan
Re: SVN Problems
« Reply #1 on: September 04, 2015, 11:38:21 pm »
Hi Dan,
I can confirm that is is definitely not working for you.
When you check-in packages then they become read-only until you explicitly check them out.
Maybe better try to start with adding a single package to SVN to see what happens.
I would use that anyway instead of the "branch" operations as it allows more control on what you put into SVN and you get better filenames.
Dan Rasmussen
Re: SVN Problems
« Reply #3 on: September 05, 2015, 12:40:23 am »
Thanks for the comments.  Knowing that it wasn't working prompted me to try to fix the error reported in number 1.  I had pointed EA to use the cygwin binary for svn (Tortoise is the standard here but not supported by EA).  The back slashes in the path made me wonder so I installed one of the apache svn binary packages for windows and that seems to have fixed things up for me.
No more errors AND I am getting expected behavior.  Thanks!
Re: SVN Problems
« Reply #4 on: September 14, 2015, 02:43:44 pm »
My recent usage of EA and svn has been with tortoise svn. Just click the checkbox on the install for command line tools.
