Author Topic: RTF-Documentation of nested child elements in EA  (Read 2407 times)
Stephan Dankers - work
« on: September 16, 2015, 11:12:41 pm »
I want to export a structure with nested elements to a RTF document, but have problems to do this.
I want to export some elements properties including the properties of connectors (e.g. type) and the elements connected to the connector (e.g. strerotype, name), in order to provide traceability information.
1
It works fine for the parent element (e.g. requirement or block).
2
Even so I've enabled "child elements" and added it to the template I cannot add information of connectors and connected elements im the template. I can just select and export the properties of the child elements itself.
3
Any grand-child elements are not exported at all.
I've thought EA is running through the structure in a recursive way, like it does for packages.
Do I need a special add-on fro this. I cannot find any information in the help or in the forum.
Thanks and regards
Stephan
