Author Topic: Display package in rectangular notation.  (Read 5806 times)
« on: September 24, 2015, 09:28:11 am »
In a diagram is it possible to display a package in rectangular notation? (i.e. similar to say a class)
Re: Display package in rectangular notation.
« Reply #1 on: September 24, 2015, 10:12:58 am »
Technically, you can, I do it via automation.
But it doesn't do you any good since the Rectangular form of the package looks the same.  :(
You might be able to assign a stereotype and do it that way...
« Reply #2 on: September 24, 2015, 02:16:17 pm »
You may as well be setting it to elephant notation. Packages don't have a rectangle notation.
« Reply #3 on: September 24, 2015, 05:38:07 pm »
[size=14]Like Simon earlier on one of my other posts, I thought I was quoting it and instead I was modifying it!
So I've now lost the original text...
[/size]
« Last Edit: September 25, 2015, 04:37:56 pm by PaoloFCantoni »
« Reply #4 on: September 24, 2015, 08:03:34 pm »
I alway wondered why Sparx does not concentrate more on the drawing aspect. UML is a graphical language. And thus, one should assume, there should be some more focus on drawing.
« Reply #5 on: September 25, 2015, 04:28:58 pm »
I always wondered why Sparx does not concentrate more on the drawing aspect. UML is a graphical language. And thus, one should assume, there should be some more focus on drawing.
"We hold this truth to be self-evident"...
As you know, I've been saying the same thing for over 10 years...
« Reply #6 on: September 25, 2015, 04:35:46 pm »
[size=14][SNIP][/size]
I presume you mean packages don't have a specified rectangular representation in UML.
If you want a rectangular package shape, use Info View in v12.1!
Concistency, konsistency, consistensy! TMUffe - after Paolo
Sunshine
  • Its the results that count
« Reply #7 on: September 25, 2015, 05:50:51 pm »
You can use UML stereotypes and shapescript
i.e.
Menu Project>Settings>UML Types
Create new stereotype for package like "Rectangle"
Add shape script like below
Then for a package select stereotype "Rectangle" and shapescript kicks in and draws a rectangle for the package.
shape main
     rectangle(0,0,100,100);
     addsubshape("namecompartment",100,100);
     shape namecompartment
          h_align = "center";
          editablefield = "name";
          println("#name#");
Hope that helps.
BTW I've just sent Martin R. at MinEdu an EA MDG which has some of these
« Last Edit: September 25, 2015, 05:55:29 pm by phenzell »
Happy to help
« Reply #8 on: September 28, 2015, 05:47:01 am »
thanks and thanks
