Author Topic: How to create a custom connector between 2 stereot  (Read 5504 times)
Stanislaw Tristan
« on: September 28, 2015, 07:36:32 pm »
Hello all!
I have a 2 requirement-based stereotypes:
  • Custom Requirement
  • Custom Requirement Test
I need to create a custom link between instances of the stereotypes above:
  • Tests - Tested By
What steps I need to do in profile?
« Last Edit: September 28, 2015, 07:37:05 pm by stristan »
Re: How to create a custom connector between 2 ste
« Reply #1 on: September 28, 2015, 08:10:55 pm »
It's the same as for any element. I would stereotype a Dependency with <<Tests>> and/or <<Tested by>>. You can add this to toolboxes like any other element in your MDG.
Stanislaw Tristan
« Reply #2 on: September 28, 2015, 08:16:20 pm »
Thank for the answer.
I forgot to specify that I need in case selection of Custom Requirement element on the diagram/specification manager - the trace window must to show me a correct links Tested By and vice versa. Is it possible?
« Reply #3 on: September 28, 2015, 09:11:13 pm »
Trace window? Do you mean the quick linker?
Stanislaw Tristan
« Reply #4 on: September 28, 2015, 09:16:54 pm »
We connect 2 elements with Dependency connector. When Traceability window is open it shows this dependency as Depend on - Needed By.
I need to create a custom connector that in Traceability window will show Tests - Tested By.
« Last Edit: September 28, 2015, 09:17:30 pm by stristan »
« Reply #5 on: September 28, 2015, 09:21:25 pm »
The traceability window will just show "depends on" in the direction of the dependency (always source-target even if you set it target-source - EAUI). The stereotype is suppressed in this window. EAUI again, I guess.
Stanislaw Tristan
« Reply #6 on: September 28, 2015, 09:23:05 pm »
Understood.
Thanks!
