Author Topic: Filename generate xsd  (Read 4428 times)
korsbecker
« on: September 29, 2015, 05:07:49 pm »
Hi
In the dialog "Generate XML Schema" in the "Child Package Options" I have to supply filenames for each package! But I have to do this every time I generate! Is there a way to set this filename permanently on the package?
I'm using EA 9.3
kind regards
Henrik
VKN
Re: Filename generate xsd
« Reply #1 on: September 30, 2015, 09:47:18 am »
For each of the child packages, add a stereotype "XSDschema"
korsbecker
« Reply #2 on: September 30, 2015, 06:07:49 pm »
Hi VKN
Did that but it does make any difference as far as I can see?
kind regards
henrik
VKN
« Reply #3 on: October 01, 2015, 10:07:00 am »
  • I just tested for 9.3 and it retains the paths for child packages.
  • I hope you have generated the XSD after adding the stereotype then reopened the dialog to check the paths for child packages.
  • Try it on a new set of packages.
  • If it didn't work, please describe the steps that you've followed.
