Author Topic: custom tagged values for stereotype "table"  (Read 3968 times)
spinky
« on: October 06, 2015, 09:39:03 pm »
I need to add custom tagged values to table and its column. I have my own profile defined with "my_table" stereotype with these tagged values, it works well. When I set on a class both stereotypes (table and my_table), it has both table and my_table tagged values, but I can't see it in Database Builder.
I tried to add tagged values directly to "table" stereotype using a profile, but it didn't work - no custom tagged values were added.
Is there a way to add custom tags to table?
Thank you for any answer
Petr Spinky Pribyl
Re: custom tagged values for stereotype
« Reply #1 on: October 06, 2015, 09:53:22 pm »
Actually I don't know in this specific case. But I know that EA handles <<table>> (and the other DB stuff) internally with special code which is not accessible from outside. Maybe one of the Sparxians can help.
« Last Edit: October 06, 2015, 09:53:43 pm by qwerty »
Uffe
Re: custom tagged values for stereotype "table"
« Reply #2 on: October 06, 2015, 10:12:48 pm »
Hi Petr,
If you create your own UML profile you can extend existing stereotypes. When you specify the metaclass to extend, the metaclass selection dialog has a tab "Stereotypes" where you can select an installed profile (EAUML in this case) and then a stereotype to extend (table and column).
This should allow you to add tagged values to tables and columns, while still allowing EA to recognize them as its own. I haven't tried it myself, but it should work.
/Uffe
spinky
« Reply #3 on: October 07, 2015, 03:55:31 pm »
Thank you for the answers. It stil does not work. It seems the solution works only for non-UML objects. I will ask sparx support
