Author Topic: problems profiling a java 64bit application  (Read 4122 times)
X. Nastos
« on: October 08, 2015, 10:50:51 pm »
I am facing a Problem regarding the usage of reverse Engineering functinoality in EA V10. What I am trying to do is to integrate the EA profiler lib into my Java-application using the Argument:
-agentpath:"C:\PROGRA~2\Sparxs~1\EA\SSJavaProfiler75"
I am using a jdk8u31 64bit Environment. I am getting following message when attempting to start the jvm:
Error occurred during initialization of VM
Could not find agent library C:\PROGRA~2\Sparxs~1\EA\SSJavaProfiler75 in absolute path, with error: %1 ist keine zulässige Win32-Anwendung
Knowing that EA is a 32bit application I don't have a clue how I could possibly avoid this error. From the view of my application I can't Switch to a 32bit jvm because of the usage of several 64bit products.
Any ideas?
Best regards,
X. Nastos
« Last Edit: October 08, 2015, 11:19:17 pm by prover »
Re: problems profiling a java 64bit application
« Reply #1 on: October 09, 2015, 08:39:48 am »
What version of EA are you using? Recent versions do support debugging 64 bit applications.
X. Nastos
« Reply #2 on: October 09, 2015, 05:10:32 pm »
I am using Version 10.0.1007
