Author Topic: Shared central EA Repo  (Read 5706 times)
Gary W.
« on: October 03, 2015, 11:58:12 am »
Hi
My org has been sending .eap file back and forth, and now we're moving to a central RDBMS shared, and with User Security and Versioning enabled.  Here's my overview of the deployment.. http://pasteboard.co/15yIEDCO.png
My big question is "is it true than XMI imports/export to and from SubVersion/SparxEA have to go through the desktop client?".  TIA
« Last Edit: October 03, 2015, 11:59:41 am by gwong »
Re: Shared central EA Repo
« Reply #1 on: October 03, 2015, 02:49:33 pm »
Yes, there's no server component, only a database.
So everything goes through the EA client on the desktop. If that poses a problem then you might consider something like Citrix.
Gary W.
« Reply #2 on: October 14, 2015, 08:52:38 am »
And now there's a proposal to move away from Subversion and have both external and internal staff use Cloud Server.  I want to avoid forcing all users to be on the release of  Sparx EA, and the same extensions/plug-ins/add-ons/etc.
Does moving to Cloud Server mean that all users have to be using the same release of Sparx EA on their desktop?
TIA
gary
« Reply #3 on: October 14, 2015, 01:43:36 pm »
No, "Cloud Server" just means that you have one repository that  is accessed over http(s).
It is meant as a WAN solution. In case of a LAN setup you better go for regular DBMS setup.
No, it doesn't matter which EA version or which add-ins are installed at the clients.
Gary W.
« Reply #4 on: October 15, 2015, 03:52:15 am »
Okay, then that's one less reservation I have about moving to this new direction.   Thanks!
