Author Topic: Merging projects or moving diagrams  (Read 5156 times)
pixelpshr
« on: October 17, 2015, 02:26:38 am »
I have two separate Sparx EA projects that now need to be combined, or at least I need to copy some of the packages and diagrams from one project to another. Is there something in EA that will help me do this?
Re: Merging projects or moving diagrams
« Reply #1 on: October 17, 2015, 02:41:32 am »
You will need to move things into packages (all you want to be exported that is in diagrams) if you have things scattered around. If you have a clear package structure already just export that via XMI and import it in the other model.
pixelpshr
« Reply #2 on: October 17, 2015, 03:39:14 am »
Thanks! I will try that.
« Reply #3 on: October 17, 2015, 03:43:07 am »
You can also do a Right Click|Copy / Paste|Copy from the project browser and Right Click|Copy / Paste|Paste. This even works between models, and is often faster then xmi export/import.
But the comment about the package structure remains the same.
« Reply #4 on: October 17, 2015, 04:12:13 am »
Ah sure. This works with V12 (it's a newer feature and IIRC not available before).
« Reply #5 on: October 17, 2015, 05:31:14 am »
I think it has been introduced in v10 or something.
« Reply #6 on: October 19, 2015, 08:22:25 am »
... is often faster then xmi export/import.
It can't be faster. Behind the scenes that's exactly what's happening.
« Reply #7 on: October 19, 2015, 08:35:27 am »
In terms of keyboard/mouse work it [highlight]is[/highlight] faster  ;)
« Reply #8 on: October 19, 2015, 10:59:31 am »
Is this XMI on a per-item (rather than per-package) basis?
If so, it ALWAYS strips GUIDs doesn't it?
« Last Edit: October 19, 2015, 05:27:25 pm by PaoloFCantoni »
VKN
« Reply #9 on: October 19, 2015, 11:21:25 am »
Is this XMI on a per-per item (rather than per-package) basis?
Yes
« Reply #10 on: October 19, 2015, 05:31:36 pm »
Yes
So it would be interesting to add the functionality to inhibit strip GUIDs and have the new items replace the originals (if they had the same GUID) - from different repositories.
