Author Topic: Options for Project::GenerateXSD  (Read 3523 times)
Kyle W Melton
« on: August 14, 2015, 04:12:46 am »
The Enterprise Architect User Guide documents the GenerateXSD method on the Project class.  The last parameter on that method is titled "Options" and the documentation lists "GenGlobalElement=1" as an example.
Can anyone provide the text for the other options available on the "Generate XML Schema" dialog box?  Other options would be things like "Use relative-path to reference XSDs" or "Generate XSD for Referenced packages"....
Thanks!
Re: Options for Project::GenerateXSD
« Reply #1 on: August 14, 2015, 08:41:12 am »
If the documentation only lists one option, that's all that's been implemented at this stage.
DarinJ
« Reply #2 on: October 20, 2015, 07:05:36 am »
Is there a way to use the GenerateXSD command to generate "include" elements that are not empty?  If I use the GUI to generate XSDs on the top-level package and tick the "Use relative-path to reference XSDs" option, the "include" elements are correctly generated.  But I cannot figure out how to use the GenerateXSD command to accomplish this.
