Author Topic: Deployment View  (Read 5248 times)
TonyN
Deployment View
« on: October 26, 2015, 04:18:43 pm »
HI All,
 Need help understanding the deployment view.  You will need to go to the example project->Software Engineering->Deployment Model->Head Office Deployment-> Ho Servers.
Once you have the diagram open you will see top centre node (Web Server) has compartment with the physical machine specification.
The question is how do you edit these values?  I cannot find anywhere to edit them and the help was not helpful.  They appear to be attributes I but can't seem to find the values to change.  e.g. I may want to change Disks = 4 x 80 GB to Disks = 4 x 120 GB.
Any help would be greatly appreciated.
 Tony
Re: Deployment View
« Reply #1 on: October 26, 2015, 05:08:47 pm »
That is the runstate, i.e. the run-time values of attributes. You edit the runstate by selecting the element instance and pressing Ctrl+Shift+R.
Sam Courtney
Re: Deployment View
« Reply #2 on: October 27, 2015, 05:05:20 am »
Also - select the element instance, right click for context menu, choose Features and Properties, then you'll see Set Run State - choose a pull down for your selection and then you can set/chng the value.
« Last Edit: October 27, 2015, 05:05:56 am by scpag »
TonyN
Re: Deployment View
« Reply #3 on: October 29, 2015, 09:29:33 am »
Thanks for the help - problem solved :)
