Author Topic: Paper Sizes  (Read 6254 times)
ssands
Paper Sizes
« on: October 23, 2015, 03:19:29 am »
Hi all,
It seems Sparx EA has a limited choice of paper sizes available. Is there a way to create a custom size? I need to print on 11" x 17" paper. This is also known as ANSI C (also Ledger or Tabloid), and is similar to A3.
However, I don't see a way to specify this size in the Diagram Properties dialogs.
Is there a way to do this? If not, I would greatly appreciate more options of paper size, including a custom for whatever definition one wants.
Wikipedia ref here: https://en.wikipedia.org/wiki/Paper_size
Thanks!
Re: Paper Sizes
« Reply #1 on: October 23, 2015, 06:32:52 am »
You just need the right printer driver. Once you have one installed that supports bigger formats you're done. Unfortunately programs like FreePDF support only up to A4.
AndyJ
  • It's only a model
Re: Paper Sizes
« Reply #2 on: October 23, 2015, 12:23:01 pm »
Add a printer driver (as qwerty suggests) for example an HP Plotter.
Then you have a huge range of potential page sizes.
I use the driver for HP DesignJet T790ps 44 inch PS3.
 :D
ssands
Re: Paper Sizes
« Reply #3 on: October 24, 2015, 02:52:28 am »
Thanks for the replies everyone. The issue I am having is that my printers don't have 11x17 as a pre-populated option - I have to define a custom size, insert the paper and it works.
So, any ideas what I would do in this situation? At this point, I am making an image of my diagram and checking it in MS Paint just to see the dimensions.
AndyJ
  • It's only a model
Re: Paper Sizes
« Reply #4 on: October 29, 2015, 10:14:31 am »
The printer driver doesn't have to be for your existing printer.
Install a printer driver that contains the page size you want.
When you print the diagram, select your REAL printer, page size remains the same.
