Author Topic: Problem reusing parameter in activity diagram.  (Read 3589 times)
Sunil V Shetty
« on: October 28, 2015, 04:58:50 pm »
I am creating an activity diagram for a login page which is required for a project I am doing. I have created an activity called "Initialize system" where all the parameters are initialized(ex : username, password, isClickedLogin ...). But I am not able reuse these parameters. For example default value of parameter "isClickedLogin" is false. But in the "login" activity I want to change its value to true.
Is there a way to do this?
Thanks in Advance.
Re: Problem reusing parameter in activity diagram.
« Reply #1 on: October 29, 2015, 09:11:30 am »
It sounds like you are directly using the activity in multiple activity diagrams. What you want is a call behavior action instead. (Which then contains action pins representing the activity's parameters)
Sunil V Shetty
« Reply #2 on: October 29, 2015, 07:16:43 pm »
Thanks for your reply. It was helpful.
« Last Edit: October 29, 2015, 07:17:14 pm by Sunil »
