Author Topic: best practice for baseline and target arch models  (Read 21745 times)
jbaragry
« on: October 31, 2015, 12:12:45 am »
What are the best techniques for modelling baseline and target architectures?
We're modelling a legacy migration in archimate and want to show how the app landscape will change over time.
Most the elements will remain the same but the connectors will change as new components replace the legacy box. E.g., in this simple example new components E and F will replace parts of D and the relevant clients (B, C) will change connectors accordingly:
If we have everything in the same model then we need many connectors to represent different time periods. If we have the baseline and target in different models then we need to copy all the elements from baseline to target and then manually update the baseline as the target gets implemented.
Are there any other alternatives?
thanks
Jason
« Last Edit: October 31, 2015, 12:13:37 am by jbaragry »
bockfu
Re: best practice for baseline and target arch mod
« Reply #1 on: November 04, 2015, 06:18:34 pm »
I am also interested in learning common practices for this scenario.
From my observations, I suspect there is no ideal solution to model this today.  An approach would be to have the 'To Be' state modeled in the same project as the current 'As Is' state.  Where the 'To Be' Model does not share elements with the current model.
Over time the current state will change and move towards the To Be state and one could save baselines of the model over time as needed.
jbaragry
« Reply #2 on: November 04, 2015, 08:30:25 pm »
Thanks for the reply.
That is what we ended up doing.
I found one other suggestion on a linkedin forum which recommends a 3rd party MDG tech that creates a profile with built-in time concepts.
E.g: you can then show that certain elements and connectors become relevant after certain projects are finished, etc
It was too much overhead for our use case so we just keep baseline and target models separate and update each manually
(the alternative I mentioned is on a closed linkedin group, but if you google "Best Practices for Baseline and Target architectures" and open the cached version of the linkedin result then you can read the thread - this forum sw barfs if I post the webcache link...)
Jason
« Last Edit: November 04, 2015, 08:40:35 pm by jbaragry »
« Reply #3 on: November 04, 2015, 09:47:07 pm »
Exactly. You can support the process by making the as-is and to-be packages (version) controlled and setup security so either part is protected against accidental changes. There should be separate groups to model the to-be and to merge to the as-is.
Glassboy
« Reply #4 on: November 05, 2015, 08:19:25 am »
You're making some strange assumptions about what a target is.  You can have multiple target architectures and as you travel towards it your target always changes.  The target can also be abandoned and replaced by something else.
Thinking that you can just adopt a target start model as your as-is model will always drive error into your as-is model rendering it useless and\or dangerous.
You should be copying your current state into a separate package to create a target state model.  Archimate doesn't have a trace relationship to relate the future state back to the current state , so you either just skip this or use an association.
At the end of your project you should be updating the current state on what actually was deployed not your target state model.  You target state model is a wish not reality.
« Reply #5 on: November 05, 2015, 03:20:15 pm »
I think it works best if you use a mixed AS-IS/TO-BE model.
Change your model already if you want something to be changed. The sooner everyone knows about the upcoming change the better.
After all, someone else is also working on a TO-BE situation.
If it so happens that they stumble upon your TO-BE changes it is in everyone's best interest that they base their changes onto the TO-BE situation, and not on the (soon to be outdated) AS-IS situation.
If not you have the risk of modelling a whole part based on the AS-IS, only to find out that, when you are ready to implement the changes, that the AS-IS has been changed in the meantime.
Key to get this working properly is to somehow mark the changes you are doing with something like : User, Date, ChangeID, Remark
That would allow another user to see if the change is recent or not, and  if so use the ChangeID to figure out if and when the change is/was implemented.
The scenario where you have multiple candidate TO-BE's is to be avoided as much as possible. If you can't avoid it then use a sandbox to model the different alternatives using copies of the actual elements. Try to keep this "sandbox" phase as short as possible as you'll have to re-do everything after deciding on a direction.
I found that often these different alternatives only need to exist during a short sketch phase.
I think you have to forget about the utopia idea of having a perfect AS-IS model that represents the actual reality. Forget the idea of having a perfect model altogether.
I've never come across a model that is perfect and complete!
Your model will never be correct nor complete, learn to live with it!. It is  perfectly OK, as long as it serves your purposes.
« Reply #6 on: November 05, 2015, 04:47:51 pm »
I have been very short in my answer since there is no really good answer to such a complex question. It all needs a lot of thinking how to handle as-is and to-be. A lot more than most people thought and still think it would take. Enough stuff for more than one thesis.
« Reply #7 on: November 05, 2015, 08:35:57 pm »
Hence version controlling a shared model is a pointless exercise.  A model is a latticed data store, not a sequential document.  We take regular snapshots and save those.
Securing packages against accidental changes is a different kettle of fish - we use user security at the group level with some degree of granularity.
« Last Edit: November 06, 2015, 10:47:58 am by PaoloFCantoni »
« Reply #8 on: November 05, 2015, 10:00:29 pm »
I can't count how often I argued against the use of VC here and on SO. So in this case the VC is just a way to lock one of the model parts against changes (the reference part).
Glassboy
« Reply #9 on: November 06, 2015, 07:06:20 am »
A model is only a partial description of reality.  That's why people need to throw away the idea that their to-be model becomes there as-is model.  The as-is model should always be drawn from reality.
I also disagree with you completely about not having multiple to-be models.  If that is what the business has asked for, that is what you need to do.
« Reply #10 on: November 06, 2015, 10:59:04 am »
"All models are wrong!  But some are useful..."  (George E. P. Box)
There can't be multiple to-be models!  There can only be multiple potential to-be models!  :)
Neil Bohr said: "Prediction is very difficult, especially about the future."
As Glassboy says, if the business needs potentially variant futures, for example under a sensitivity analysis, then the modelling technology should provide the ability to represent them, without each one tripping over the other's feet.
If it's an as-is model, then it should be best obtained by reverse engineering.  As I have mentioned here before, the OMG CIM, PIM and PSM, for example, are design models.  You need to create what I call the PSI - the Platform Specific Implementation to compare as-built with as-designed.
« Last Edit: November 06, 2015, 11:02:57 am by PaoloFCantoni »
brback
Re: best practice for baseline and target arch models
« Reply #11 on: April 20, 2017, 04:23:58 am »
Is there any new best practices regarding this topic?
We're building an architecture repository based on TOGAF, but have some troubles on finding the best way to organize the repository (architecture landscape) in the time dimension (as-is, to-be, transition, etc.). Time-aware modelling might be useful, but I'd really like to hear what you consider is most practical and feasible.
Sunshine
  • Its the results that count
« Reply #12 on: April 20, 2017, 08:08:34 am »
Yes its a difficult task dealing with temporal shift in a multidimensional model. A lot of the modelling tool vendors struggle with it and believe you me I've spoken to quite a few over the last 30+ years. I once implemented a temporal aware system for a government archives system to track which agency was responsible for which function over the course of time so they could find archived artifacts. If anyone has followed government changes over the decades they'll know what a challenge it is to find who looked after something like births and deaths 40 years ago. Anyway the way I handled it for that project was to have each element and relationship have state and date fields then filtered on those to find what was related to what at a point in time and what was current. With that in mind I structure my enterprise model following the usual Archimate domains like Motivation, Business, Application, Data, Technology etc. Under each of those I have catalogs of elements where I put the elements and views where I draw diagrams for current and future states. One idea I'm working through is that each element has a state, for instance, proposed, approved, implemented, retired etc. You can have additional attributes added as tag values like commissioned date and de-commissioned date to record when it went live or when it was retired. The diagrams I create usually have the current state and some future vision with multiple interim states reflecting alternative paths to reach the future state. Some times these diagrams are separate and sometimes if the changes aren't too drastic I'll use diagram filters to show the current state moving to the future state. In the reports I create I'll use the state and dates to filter out what I need to reflect the current, interim or future states. This works most of the time for me except when the links change without a node change. Kind of needs some state on the link to indicate if its current or future and that's the part I'm thinking about at present. But hey actual work gets in the way of fixing up your tool set doesn't it?
So how is my model I structured you may ask? Well something like this
Business
   Catalogs - where the elements are strored and shared.
       Events
       Processes
       Roles
       Actors
   Views - where the diagrams are created
       Current State
             Business Process
                 Finance
                 Human Resources
                 Information Technology
                 etc
       Target State
             Business Process
                 Finance
                 Human Resources
                 etc
Application
Data
Like it was quoted before by Paolo "All models are wrong but some are useful" from George E P Box. This works mainly for me but not always and it certainly not perfect. One pain is that the elements by default are created in the same package as the diagram so I've got to shift them into the catalog package all the time. (Thinking about that may I should write a script to automate it)
Note that to be able to do this successfully you really need to create your own MDG and not use the out of the box ArchiMate MDG or whatever notation you use as you need to add those extra attributes and additional behaviors using shapescripts, javascripts etc. Its a hard slog doing your first EA MDG but the rewards and additional benefits do come with it. I found you really need a toolsmith on the team to tweak the modelling tool to do what you need and I'm usually end being the toolsmith.
One day I might fix up my EA MDG and share it but its not quite in a state for general consumption as its too specific to my organisation at present.
Happy to help
« Reply #13 on: April 20, 2017, 10:14:14 am »
To add to Sunshine's response, we HAVE implemented mechanisms (direct SQL Queries) to move objects into standardised locations (depending upon their context).
We HAVE implemented our own MDG to add tagged values and also to add additional metatypes (both vertices and arcs).
We have implemented a special "Transition" relationship to allow us to indicate which items and arcs transition from baseline to target (allows us to ensure that we have "covered all the necessary bases".
Using the transition relationship we create "state" diagrams for each plateau (and/or project stage) and transition diagrams for the transitions between each plateau.  The state diagrams show commissioned/decommissioned/changed/unchanged items and arcs with respect to that state.  We use user specific diagram properties to show the: Transition type, Timing, Scope for an element or arc (well not arcs, since EA doesn't YET??? support user specific diagram properties for arcs).
peterc
« Reply #14 on: April 20, 2017, 06:42:34 pm »
I suggest that you have a look at the Time Aware modelling concept recently introduced (EA13 I think but I stand to be corrected). I have used it to track changes to requirements not Archimate elements so you'd need to see if it works for you the way you expect to make changes. Time Aware models certainly save you copying everything over as they use your existing model except for where you introduce changes.
