Author Topic: Insert Related elements function: other conn. typ  (Read 3331 times)
Bv76
« on: November 09, 2015, 03:48:12 am »
I would like to use Insert Related elements to populate a diagram with "Requierements". These Reqs are nested (having owns-owned by relation). Some of them also have manually created "Composed by" relations. When I'm using the Insert Rel Elements function, I can choose only Aggreagtion as "Connector types" which lists the composed by elements but did not list other elements with owner relationship type. Is there a way to extend this function to select ownership connector types? I really do not want to build the hierarchy again using composed by relations.
Viktor
Re: Insert Related elements function: other conn.
« Reply #1 on: November 09, 2015, 05:17:27 am »
You can only extend this by writing your own automation. You can send a feature request too. But only if you have lots of time until seeing it implemented.
