Author Topic: DBMS Backups to File  (Read 5702 times)
bockfu
« on: October 31, 2015, 04:04:43 am »
Can someone verify the Project/Project Transfer process does not impact the 'source'?
Use Case: Save DBMS backup to EAP file
Goal: The model owner wants to save a snapshot of the project saved as DBMS on periodic bases to have a redundant backup.
I was just going to use the 'Transfer Type' of 'DBMS to File', but wanted to make sure this process will keep the DBMS as-is.
Re: DBMS Backups to File
« Reply #1 on: October 31, 2015, 04:17:04 am »
I can confirm that your source won't be changed in any way if you do a model transfer.
bockfu
« Reply #2 on: November 01, 2015, 04:23:29 pm »
Thank you Geert for confirming.   That is what I would expect.
bockfu
« Reply #3 on: November 06, 2015, 06:25:31 pm »
So I successfully transfered DBMS to File.
When I open the file I am prompted for login/password which I wasn't expecting.
I have been unable to use my credentials to open the file.
Any pointers on this, for example, how to disable the security settings?
« Reply #4 on: November 06, 2015, 07:33:47 pm »
There's a known bug regarding the two types of password encryption.
I posted it about a month or so ago.  You should be able to search for it in Bugs and Issues.  That may be what you are seeing.
« Reply #5 on: November 07, 2015, 02:51:11 am »
You can try to first clean the contents of t_secpolicies. This will disable security.
bockfu
« Reply #6 on: November 12, 2015, 04:47:36 pm »
root cause: the security used for the DB is applied to the saved file, but the authentication method is not functional once you access the file.
Fix (Workaround):  Create user manually with Admin permissions and manually set their password.   Transfer to File, open file, use user/password which was created manually.
