Author Topic: Icon for pattern (the next step)  (Read 3240 times)
« on: November 12, 2015, 06:24:20 pm »
So I got on my feet again with menus but stumbled again over the next weed as I wanted to set an icon for my pattern. As a default a pattern in the toolbox appears with the stereotype guillemets. The help now tells this
set the icon for a Toolbox item:
1. Locate the item in the Toolbox Items list and click within the Toolbox Icon column.
2. Click on the ellipsis (…) within this column. The Select a Toolbox Icon dialog displays.
But again: where is the "Toolbox Icon column"? I looked in the Stereotype class that extends ToolboxPage. but this of course has just a plain attribute list which does not have any  "Toolbox Icon column".
P.S. I got around this by using the ToolboxItemImage. Alas, I'd like to know what the help tried to tell me.
« Last Edit: November 12, 2015, 06:29:46 pm by qwerty »
Re: Icon for pattern (the next step)
« Reply #1 on: November 12, 2015, 07:28:25 pm »
The help is explaining how to use it with the MDG helper technology I think.
If you right click on your stereotype and choose "Open with Profile Helper" you'll see the icon option.
« Last Edit: November 12, 2015, 07:29:31 pm by Geert.Bellekens »
« Reply #2 on: November 12, 2015, 07:34:16 pm »
Ah, thanks. Yes, they refer to it. Why mention it :-X
Actually this finally does what I then did manually.
« Last Edit: November 12, 2015, 07:35:10 pm by qwerty »
