Author Topic: Link to Element Feature  (Read 4396 times)
Michel777
« on: November 16, 2015, 08:58:27 pm »
is it possible to link attributes within the same class ?
Michel
« Last Edit: November 16, 2015, 08:58:48 pm by michel777 »
Re: Link to Element Feature
« Reply #1 on: November 16, 2015, 09:42:46 pm »
Have you tried it? :D
Edit:
I just did and it doesn't work  :-?
« Last Edit: November 16, 2015, 09:45:29 pm by Geert.Bellekens »
« Reply #2 on: November 16, 2015, 09:51:42 pm »
Attributes in a class are linked due to the fact that they are inside the same class. And there they should have different purpose.
Uffe
« Reply #3 on: November 17, 2015, 01:27:30 am »
Hi Michel,
The context menu item is disabled on self-referencing connectors.
I tried to hack my way around by creating a copy of the class, drawing the connector between them, linking to two different attributes, then moving one end of the connector to refer back to the original class -- no go. The end that was linked to an attribute becomes unlinked.
It might be possible to achieve with a more involved hack which bypasses the GUI and updates the database directly, but I'm thinking that if they've gone to the trouble of implementing the unlink-on-connector-move there's probably a good reason.
Cheers,
/Uffe
Michel777
« Reply #4 on: November 17, 2015, 03:56:43 am »
Uffe: thanks a lot for your effort !
Glassboy
« Reply #5 on: November 17, 2015, 07:37:19 am »
To understand recursion, first you have to understand recursion?
