Author Topic: JSscript vs JavaScript  (Read 4625 times)
lubos
« on: October 21, 2009, 10:09:33 pm »
this line is valid in Scripter for JScript
var xmlDOM = new ActiveXObject( "MSXML2.DOMDocument.4.0" );
but it's not valid for JavaScript.
What I have to write to use any COM object using JavaScript?
Thanks for any hint.
Oliver F.
  • ArenĀ“t we all in the model business ?
    • Karl Storz homepage
Re: JSscript vs JavaScript
« Reply #1 on: October 23, 2009, 12:26:54 am »
You can't.
JScript uses the Windows scripting engine which enables access to ActiveX and COM.
JAVAScript does not.
Oliver
mrf
« Reply #2 on: October 23, 2009, 04:59:22 pm »
Oliver is correct that it is not supported natively by JavaScript. We do provide a COM wrapper library though that is accessible from JavaScripts within the EA JavaScript engine.
To create a COM object, the syntax for named objects is:
var obj = new COMObject("WMPlayer.OCX");
or for ClsIDs
var obj = new COMObject("{6BF52A4F-394A-11D3-B153-00C04F79FAA6}");
Please note the curly braces ({}) are required for ClsIDs.
Best Regards,
Michael
