Author Topic: Export DDL to different DBMS?  (Read 4212 times)
Bill Egge
« on: November 24, 2015, 01:33:43 am »
Is it possible to convert a database model from one DBMS to a different one?
I have imported a table structure from Pervasive and would like to generate a SQL Server version of it.  If I try to generate the DDL I get an error saying "Pervasive.SQL" does not exist or something like that even though I setup the project and imported as SQL Server 2012.
MMA
Re: Export DDL to different DBMS?
« Reply #1 on: November 24, 2015, 09:09:06 am »
There are two processes:
1. Import: connect to the database from EA and import the schemas
Then EA will have a model, you can change this model's database to another DBMS.
2. Export: Export this model as .SQL or Execute the generated sql to create tables/indexes/procedures....
However, I'm not quite sure whether "Pervasive" is supported or not.
« Last Edit: November 24, 2015, 09:13:22 am by milesma »
