Author Topic: cannot change the involved columns of a constraint  (Read 8475 times)
rocketboy2000
« on: December 03, 2015, 07:02:14 am »
I know I've done this before but I've plum forgot how to do it and its not obvious from EA messages.
I have a physical data model that I need to adjust to add a foreign key attribute to an entities primary key (make the foreign key identifying). when I attempt this from the "columns and constraints" property dialogue I get the message:
"Cannot change the involved columns of a constraint that is part of a foreign key relationship. Please use the foreign key property window."
I've tried completely deleting the association between the two entities and the foreign key constraint. but I still get the same message which prevents me from adding the attribute to the primary key.
any direction most appreciated.
MMA
Re: cannot change the involved columns of a constr
« Reply #1 on: December 03, 2015, 11:34:30 am »
I've tried completely deleting the association between the two entities ...
There are two kinds of delete:
shallow delete: simply delete the link on the diagram; the relationship is still there. You can bring it back by: Property on the element | Links | select the relationship in the list | context menu | Show Relation
deep delete: the relationship is deleted. (Ctrl + Delete)
Try the deep delete; otherwise contact the support
