Author Topic: Adding templated elements to SpecificationManager  (Read 3285 times)
G Ignacz
« on: November 30, 2015, 09:45:38 pm »
I don't know if it is a bug or feature.
After defining a template package using Project / Settings / Project Template Package, I can use the elements of that package as templates when adding new elements to a diagram. This is fine.
But when adding new elements
- in the project browser
- or to a list view
- or to as requirement list view
this feature does not work.
E. g. I would like to use Requirement objects with some template text in the Notes field. It only works if I add the objects to a normal diagram first, then change the view to Requirement Manager.
This is quite inconvenient, if you have to use nested objects.
There is a workaround however:
1) throw all elements to a diagram,
2) then set up the tree in the project browser
3) and then set to Specification Manager view.
Thank you.
Best regards, Gergely
G Ignacz
Re: Adding templated elements to SpecificationMana
« Reply #1 on: November 30, 2015, 09:47:53 pm »
ps. I am using EA 12.
G Ignacz
« Reply #2 on: December 03, 2015, 08:58:46 pm »
To those who may be interested,
as I know from Sparx Support, this behavior is a bug, and has been filed under issue number 15112776.
Best regards, G.
