Author Topic: Export / Import - visibility information lost  (Read 4709 times)
Michel777
« on: December 05, 2015, 09:07:00 pm »
After export / import the visibility information has been lost. I see neither attributes nor operations more (on the diagram). Is there anything to consider when importing / exporting?
Thanks a lot in advance,
Michel
« Last Edit: December 05, 2015, 09:07:32 pm by michel777 »
Re: Export / Import - visibility information lost
« Reply #1 on: December 06, 2015, 01:33:38 am »
Import/Export how?
Michel777
« Reply #2 on: December 06, 2015, 06:26:24 am »
EXPORT: Package; Import / Export; Export Package to XMI
IMPORT: Package; Import / Export; Import Package from XMI
« Last Edit: December 06, 2015, 06:26:54 am by michel777 »
« Reply #3 on: December 06, 2015, 08:22:50 am »
Just tried with 1215. No problem there.
« Reply #4 on: December 06, 2015, 04:05:12 pm »
Xmi import/export should give you an exact copy of the package you are exporting.
Check that first (without looking at diagrams).
Make sure the operations and attributes are exactly the same.
A reason for them not showing up on a diagram might be one of the general options for diagrams, or a diagram specific option in the diagram properties.
Geerr
Glassboy
« Reply #5 on: December 07, 2015, 07:24:48 am »
Geerr
A common cause of confusion is when people have elements outside the package they export.
